Hi, I want to make the same text movements as in the original video, but I'm a beginner and I'm not succeeding. Could you help me?
This is a original video: https://vimeo.com/156952560
Here is project folder with files:
https://drive.google.com/file/d/1c3QSBmOWNZzF86FoMvhSYszpgxPq4Zv-/view?usp=sharing
You would get far more help by using the Magix forums. That is the main support forum for Vegas users. I used to post over there all the time (over 5,000 posts). Creative Cow is another alternative.
Short answer: use keyframes in the pan/crop dialog box. Use the pan/crop controls to change the zoom, rotation, horizontal, and vertical positions at a point in time. Move to another point in time and do the same thing. Vegas will interpolate each frame in between those two points.
For text, you may be able to use keyframes in the text box itself. However, Vegas has so many different ways to put text on the screen that you'll have to provide more details of which text tool you are using. Again, the Magix forums will be a far better place to get an answer.
Help with adding same text properties to multiple clips (Sony Vegas)
By KiwiGaming in forum EditingReplies: 6Last Post: 19th Jun 2016, 06:10 -
Weird vegas avc to xvid encoding problem text in video file
By duhmez in forum EditingReplies: 1Last Post: 20th Sep 2014, 10:48 -
Monitor Is Making my Text Blurry
By imdaman in forum ComputerReplies: 43Last Post: 2nd Sep 2014, 14:25 -
making open/burnt-in caption with vegas pro 12
By darknesslord in forum EditingReplies: 27Last Post: 15th May 2014, 18:38
